2490
_DoubleClickCell and ClickCell
I have two event for my grid.
ClickCell to view PDF on my panel on my winform
And DoubleClickCell to open PDF with Adobe reader.
But it s really hard to do double click when I have Event ClickCell.
Do you have solution for that ?
Francois.
  • 21795
    Hello Francois,
    This is expected behavior. There is no way to stop click event and to fire only double click one, only when the last one occurs.
    What you can do to distinguish which event was fired is roll back the click action if double click happens, or use MouseDown event and Timer to verify whether user performed Click or Double Click. Please check the following article in MSDN where you may find additional information related to how you can distinguish clicks and double-clicks as well as samples showing how to implement both above mentioned approaches  https://msdn.microsoft.com/en-us/library/ms171543(v=vs.110).aspx .
    Thank you for using Infragistics Controls.
