585
Binding / allocation to GanttView slow
In my Gantt-View, data binding is taking ages.
Initial binding takes more than 30 seconds for a few thousand records, updating is slightly faster at around 8 seconds.
Even more puzzling, after update data has been merged (DataSet merge), I try to restore the last active task. When I allocate the task to the GanttView's ActiveTask property, again it takes longer than 30 seconds.
// re-select formerly selected task
if (_lastActiveTask != null)
foundTask = FindTask(_calendarInfo.Tasks, _lastActiveTask);
if (foundTask != null)
ultraGanttView.ActiveTask = foundTask;  <--- this takes ages
When I remove this allocation, the system will hang at the next allocation to the gantt chart:
// re-set scrollbar position
if (_firstVisibleTask != null)
foundTask = FindTask(_calendarInfo.Tasks, _firstVisibleTask);
ultraGanttView.EnsureTaskInView(foundTask, true); <--- this takes ages, when code above is removed
To sum up, always the first allocation plus binding and updating is taking far too long. I assume I missed out on some weird setting and appreciate any help :)
Before doing all that stuff, of course I do this:
ultraGanttView.BeginUpdate();
ultraGanttView.SuspendLayout();
