Hello!
I have the WinTab control initially drawn with 2 tabs and some shared controls. When I dynamically add a new tab, the shared controls disappear on all of the tabs. Any ideas as to why this is happening? Here is my code:
private void btnAddTab_Click(object sender, EventArgs e) { // Call BeginUpdate to prevent the display from // refreshing as we add individual tabs. // Note: This MUST be paired with a call to // EndUpdate below. tabcTest1.BeginUpdate(); // Specify that mnemonics will be supported. If so and // there is an '&' in a tab's text, the following character // will be treated as an accelerator (i.e. the tab will // be activated when the user presses the 'Alt' key and // that character). tabcTest1.UseMnemonics = DefaultableBoolean.True; UltraTab tabAdded; UltraTabsCollection tabs = tabcTest1.Tabs; //create a key...which I also use for the tab title in this test code int tabCount = tabs.Count; tabCount++; String newTab = "tab" + tabCount.ToString(); // Add a tab to the Tabs collection tabAdded = tabs.Add(newTab, newTab); // Select the 'options' tab by setting the SelectedTab // property. This will raise the ActiveTabChanging, // ActiveTabChanged, SelectedTabChanging and // SelectedTabChanged events. It will also cause // the 'options' tab TabPage to be made visible and // the tab to scroll into view. tabcTest1.SelectedTab = tabs[newTab]; // Give the tab control focus tabcTest1.Focus(); // Call EndUpdate to allow the display to refresh tabcTest1.EndUpdate(); }
I had a similar problem with 2008 vol.1. A part of the screen would not refresh, when adding tabs dynamically.
page.Selected = true;
I did get it working...can't remember what I did exactly now...but it's working properly...thx
I used your code but I was unable to reproduce the problem. I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp.
