380
UltraCalculator ParseString Issue
I have an issue with using the ParseString Sub.  I am setting the ParseString property to say "225" before opening the UltraCalculator. After I open the Calculator the text displayed is 225 as expected. But if the use clicks another number, it appends itself to 225.  (if 4 is clicked, the new display is 2254). I need a way to clear the display and start new if the user clicks some number.
 -Saravanan.
  • 37774
     Saravanan,
    You could try using the BeforeButtonClicked event and clear the display as necessary.  You would likely need to keep a flag saying whether you should clear the display (i.e. set this flag at the same time you set the value to 225 ), and reset this flag after you clear the display.
    -Matt
