405
PivotGrid Group Total
Not sure if this happens with regular dataset but when using FlatDataSource if you have multiple Rows you are Grouping by the "Group" Total doesn't reach Past 1 sub group as Shown.
In this example we have Line Type -> Product ID -> Part Name
When you exapand Line Type and Product ID the Total Line for Line Type and Product ID do not stretch across the two other groups so you end up with a very strange "subgroup" that is basically the grand total of all the items without braking them down.
This is a bit hard to explain but I will try to show it visually the groups highlighted in Red should not be there, rather the Total Column (in green) should extend out to show the total for that group
Here is an example if it working correctly in one of your youtube videos (here the green columns extend the complete length of the row to show the totals)
Not sure if its just a setting or if its an issue with using the FlatDataSource
