2005
Programmatically change column header height
I am trying to set the column header height programmatically:
ultraGrid.DisplayLayout.Bands[0].RowLayoutStyle = RowLayoutStyle.ColumnLayout;
ultraGrid.DisplayLayout.Override.AllowColMoving = AllowColMoving.WithinBand;
ultraGrid.DisplayLayout.Override.RowSizing = RowSizing.Fixed;
ultraGrid.DisplayLayout.Bands[0].Columns[0].RowLayoutColumnInfo.PreferredLabelSize = new System.Drawing.Size(0, (int)_columnHeaderHeight);
The column header height is set to the height correctly. However, this gives me two issues:
1. The column header height can be changed by user. Is there a way to disable this?
2. The column headers can be dragged into multiple rows of headers. User is only allowed to drag a column to a different position horizontally.
Shaolin
  • 1225
    Verified Answer
    Hi Shaolin,
    You can set the LayoutLabelSizing and LayoutColMoving properties in the Grid Override to disable the Label sizing and Column moving vertically.
    ultraGrid.DisplayLayout.Override.AllowRowLayoutLabelSizing = RowLayoutSizing.Horizontal;
    ultraGrid.DisplayLayout.Override.AllowRowLayoutColMoving = Infragistics.Win.Layout.GridBagLayoutAllowMoving.AllowOriginXChange;
    Josheela
