85
Error setting text to UltraUiaComboBox with CodedUI
I get the following error when the Coded UI Test Builder try to run a recorded tests that setting the text in the UltraUiaComboBox:
Test method CodedUITestProject1.CodedUITest1.CodedUITestMethod1 threw exception:
System.NotSupportedException: Property "EditableItem" could not be set due to current state of ComboBox
Result StackTrace:
at Microsoft.VisualStudio.TestTools.UITesting.UITestPropertyProvider.MapAndThrowException(Exception exception)
   at Microsoft.VisualStudio.TestTools.UITesting.UITestPropertyProvider.SetPropertyValueWrapper(UITestControl uiControl, String propertyName, Object value)
   at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.SetPropertyValue(String propertyName, Object propertyValue)
   at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.SetPropertyPrivate(String propertyName, Object value)
   at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.<>c__DisplayClass3e.<SetProperty>b__3d()
   at Microsoft.VisualStudio.TestTools.UITesting.CodedUITestMethodInvoker.InvokeMethod[T](Func`1 function, UITestControl control, Boolean firePlaybackErrorEvent, Boolean logAsAction)
   at Microsoft.VisualStudio.TestTools.UITesting.UITestControl.SetProperty(String propertyName, Object value)
   at Microsoft.VisualStudio.TestTools.UITesting.WinControls.WinComboBox.set_EditableItem(String value)
   at CodedUITestProject1.UIMap.RecordedMethod2() in c:\MES\TFS\GeneralProjects\TFS services\CodedUITestProject1\CodedUITestProject1\UIMap.Designer.cs:line 168
   at CodedUITestProject1.CodedUITest1.CodedUITestMethod1() in c:\MES\TFS\GeneralProjects\TFS services\CodedUITestProject1\CodedUITestProject1\CodedUITest1.cs:line 31
Can anyone help with that error? I feel hopeless!
  • 2575
    Vered,
    Please obtain and register a key for Infragistics products. CodedUI is only supported with licensed products.
