first:
now to the problem:
The following is such a sample script. Without wrapping the case statement into brackets, or prefixing "name" as "rt.name", the .GetText function returns garbage after the code " and name in". With my breakpoint in the sample you can clearly see, that GetText returns "Y " instead of "BY" in the following nodes, and also the literals '123','456','789' are already split up in a weird way as in the span objects.
cppanda
we're having the same issue with different statements and would be happy about a bugfix.
Hi cppanda,
Thank you for the sample, I was able to reproduce the highlighting issues mentioned. As such I have logged a development issue so that our developers may investigate this. The dev issue ID is 221181. I have also created a private support case for you so that you may track the status of this dev issue. The case number is CAS-174558-H2W3T6. You can view the case here.
