Recently, we ran into an issue where node text was getting cut off due to the width of a node. I haven't been able to find a way to manually control node width, so it's hard to work around.
This only seems to occur when all appearances (default, selected, active, hottracking) have smaller text than the node-specific appearance.
The situation can be reproduced using the attached files.
Can someone point me in the right direction code-wise, to prevent the text from getting cut off?
Hello Anne,
I have investigated your issue, and I have asked our engineering staff to examine “Node with bold text is cut off” further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of #221193. So I’ve created a case for you CAS-174600-W1S0N2 and will update you for the progress of this issue via the mentioned case. You could reach your case following the link below:https://ko.infragistics.com/my-account/support-activity
Hi Milko,
Thank you for your swift response!
I'll keep an eye on the case.
Hi Anne,
The fix for development issue 221193 is available in the latest service release available from the My Keys and Downloads page.
