85
Trying to skip cells...
I've got a grid set up that's got five columns and only two are editable.  Instead of making my poor user slog through the three fixed cells, I'd like to be able to hop from one to the next.  I tried the following bit of code:
Private Sub grdOpenItems_AfterCellUpdate(sender As Object, e As CellEventArgs) Handles grdOpenItems.AfterCellUpdate
    If Not isLoading Then
        If e.Cell.Column.Key = "Apply-To" Then
            e.Cell.Row.Cells("Amt. Applied").Activate()
            grdOpenItems.PerformAction(UltraGridAction.EnterEditMode)
        End If
    End If
End Sub
..in the hopes that it would allow me to skip the un-editable cells.  No dice.  It just goes to the next cell over as it would if no event code was present.  I've traced through the code and know the .Activate() and PerformAction calls are happening.
Suggestions?
Thanks!
g.
