hi all,
I want to add a tree control to a group at the design and place it right under the group name. But when I drag the tree control to explorer bar, there is no where on the group to drop and dock. Has anyone done this before?
Thanks in advance.
// You can use either the control's GroupSettings or the settings object// for a specific group.//UltraExplorerBarGroupSettings groupSettings = this.ultraExplorerBar1.GroupSettings;UltraExplorerBarGroup group = this.ultraExplorerBar1.Groups[0];UltraExplorerBarGroupSettings groupSettings = group.Settings;
// Set the Style property to 'ControlContainer', so that no items// appear, and a container control is displayed instead.groupSettings.Style = GroupStyle.ControlContainer;
// Set the 'ContainerHeight' property to change the height of the// group (applicable only when the group is expandable, as is the// case when the control's Style property is set to 'ExplorerBar'// or 'VisualStudio2005Toolbox').groupSettings.ContainerHeight = 300;
// Create an UltraTree and add it to the group control container's// Controls collection.UltraTree treeControl = new UltraTree();treeControl.Nodes.Add( "One" );treeControl.Nodes.Add( "Two" );treeControl.Nodes.Add( "Three" );treeControl.Dock = DockStyle.Fill;
group.Container.Controls.Add( treeControl );
How to do it from the code ?
Thanks in advance,
Thomas
In the UltraExplorerBar Designer, Under the tab Control Styles, select ControlContainer as GroupStyle, now you can drag-drop the controls on groups. Check the attached image
