No matter what I try I can not get the grid lines to be any color other than light gray. I have tried many combinations including the below to no avail...
grdWork.DisplayLayout.Appearance.ThemedElementAlpha = Infragistics.Win.Alpha.Transparent grdWork.DisplayLayout.Appearance.BorderColor3DBase = Color.Red grdWork.DisplayLayout.Appearance.BorderColor = Color.Red grdWork.DisplayLayout.Appearance.BorderColor2 = Color.Red
What am I missing?
Hi Nikolas,
Setting these properties on the override should change the Grid lines color. If the Grid lines color remains the same then something in your application must be changing the BorderColor of cells or rows.
To identify what’s causing this behavior, Please verify the following:
• If you are loading any isl file and if it is overriding the settings you apply in code. • Whether you are setting these properties somewhere else after you set them here. • If you are loading a layout, which is overwriting the existing settings.
Sincerely,Sahaja KokkalagaddaAssociate Software Developer
Alternatively, you can also change the Grid lines color by using RowAppearance and CellApperance objects off the override. For example you can do this:
this.ultraGrid1.DisplayLayout.Override.RowAppearance.BorderColor = Color.Red;this.ultraGrid1.DisplayLayout.Override.CellAppearance.BorderColor = Color.Red;
Please let me know if I may be of further assistance.
Yes I did that to no avail...
what I had to do was
1. Cycle through cells and change border
2.Cycle through rows and change border
code is below...
For Each gridRow In grdWork.Rows 'DR = CType(gridRow.DataBoundItem, System.Data.DataRowView).Row DR = CType(gridRow.ListObject, System.Data.DataRowView).Row 'gridRow.DefaultCellStyle.ForeColor = Me._presenter.GetItemColor(DR) gridRow.CellAppearance.ForeColor = Me._presenter.GetItemColor(DR) gridRow.Appearance.BorderColor = Color.Black gridRow.Appearance.BorderColor2 = Color.Black Next
My first thought is always to turn off UseOSThemes on the control. I'll take a look and see if there's more to do here but that's always my go to!
