65
Resizing quick access toolbar configuration button
Hello!
I'm developing a DPI aware application and I want to increase the size of the buttons and icons in the quick access toolbar.
When I set the ImageSizeSmall property on the toolbarsmanager it scales the command buttons properly in QAT but the configuration button remains small.
How can I increase the size of the QAT configuration button and its icon?
I made the following sample to demonstrate my problem:
public partial class Test : Form
        private Infragistics.Win.UltraWinToolbars.UltraToolbarsManager toolbarManager;
        public Test()
            InitializeComponent();
            this.Size = new Size(600, 400);
        private void Test_Load(object sender, EventArgs e)
            toolbarManager = new Infragistics.Win.UltraWinToolbars.UltraToolbarsManager();
            toolbarManager.DockWithinContainer = this;
            var tool = new ButtonTool("Button1");
            toolbarManager.Tools.Add(tool);
            var tabGroup = new RibbonGroup("Key2", "TabItem1");
            var tab = new RibbonTab("Key1", "Tab1");
            tab.Groups.Add(tabGroup);
            toolbarManager.Ribbon.Tabs.Add(tab);
            toolbarManager.Ribbon.QuickAccessToolbar.AddRemoveTool(tool, 0);
            toolbarManager.Style = ToolbarStyle.Office2010;
            toolbarManager.Office2007UICompatibility = false;
            toolbarManager.Ribbon.FileMenuStyle = FileMenuStyle.ApplicationMenu;
            toolbarManager.Ribbon.Visible = true;
            toolbarManager.Style = ToolbarStyle.ScenicRibbon;
            toolbarManager.ImageSizeSmall = new Size(32, 32);
  • 210
    Verified Answer
    Hi Gabor,
    I attached a sample that utilizes DrawFilter and CreationFilters to draw a new larger image into the QAT button.
    Let me know if you have further questions.
    Ari Shaposhnik
    Sample.zip
  • 210
    Hi Gabor,
    Unfortunately there is no simple way to do this, to get the intended effect we need to use DrawFilters and CreationFilters. I am writing up a sample to show you how this can be done and will send it shortly.
    Ari Shaposhnik
