Nevermind - i figured it out.
It helps to get all the columns for the drop down and not hide any and not have a custom concatenated field as the first column.
Original question left here below
side by side - one not working
On same form i have side by side two grids - each with a dropdown.One from Northwind and the other from my database.
No bells or whistles. Yet the dropdown arrow does not appear for mydb when you hover over the ResourceTypeID. Hence no dropdown.
The "Description" is displaying properly but there is no dropdown in the grid. Why? Corruption? Key definition?
private void Form5_Load(object sender, EventArgs e) { // my DB this.bEAProjectProject6LookupTableAdapter.Fill(this.bEATimesheetDataSet.BEAProjectProject6Lookup); this.bEAProjectProject6TableAdapter.Fill(this.bEATimesheetDataSet.BEAProjectProject6); bEAProjectProject6LookupDD.DisplayMember = "Description"; bEAProjectProject6LookupDD.ValueMember = "ResourceTypeID"; // NorthWind this.categoriesTableAdapter.Fill(this.dataSet1.Categories); this.productsTableAdapter.Fill(this.dataSet1.Products); categoriesDataGridDD.DisplayMember = "CategoryName"; categoriesDataGridDD.ValueMember = "CategoryID";
//productsDataGridView1 grid //categoriesDataGridDD DD
//bEAProjectProject6LookupGrid grid //bEAProjectProject6LookupDD DD
private void productsDataGridView1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) {
e.Layout.Bands[0].Columns["CategoryID"].ValueList = this.categoriesDataGridDD; e.Layout.Bands[0].Columns["CategoryID"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList;
private void bEAProjectProject6LookupGrid_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Bands[0].Columns["ResourceTypeID"].ValueList = this.bEAProjectProject6LookupDD; e.Layout.Bands[0].Columns["ResourceTypeID"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList;
Hello buckland,
thank you for your feedback and for sharing this with our community members.
Please do not hesitate to ask if something comes up.
