270
Issue in exporting wingrid to excel
Hi Mike,
After I export a column whose data type is string to excel, in the exported file, I found an issue.
The column contains a cell whose value is a percentage, three rounding positions after the decimal. When I double click the cell, it will automatically use the default round off rule and there're only two rounding positions left.
My question is how can I display three rounding positions even I double click the cell?
Pls refer to the attachment for details.
Thank you~
  • 469350
    I'm not sure what double-click in the cell does. But I am guessing that the problem is that the initial value of the cell is being written to Excel as a String and not a numeric value and when you double-click, Excel is changing it to a number and formatting it with only 2 digits. The grid and the exporter have no control over how Excel converts strings into numbers. You can probably right-click on the cell in Excel and change the Format.
    One way you might get around this is to export the value as a number instead of a string. You would have to handle the SummaryCellExported event and write a numeric value to the excel worksheet cell. I guess you would also need to set the Format on the cell.
