I want to center the legend on the right side of the chart. Can I custom the legends location or the position on its location?I have only found 4 locations for the chart legend (top, left, right, bottom). For my chart (chart type “Column Chart”) I used the location “right”. However I want to center the legend, also if the size of the chart is changed (layout, Dock -> fill).Is it possible? How can I implement it?
Thanks and regards,
Harald
Hello Harold,
I found that it is not possible to set the specific position of a normal chart. It is possible to set the legend's position of a Composite Chart. I've attached a sample which demonstrates how to create a composite chart and specify the position of the legend.
Hello Harold,I have also found that the legend can only be positioned in those four locations. I will continue to research to see if there is a way to position the legend anywhere but the preset locations.Please let me know if I can assist you further.
