20
UltraWinGrid: GroupByRow -Sort within single group at a time
Hi
I am using the UltraWinGrid as follows
grdDiaryItems.DisplayLayout.ViewStyleBand = ViewStyleBand.OutlookGroupBy ;
grdDiaryItems.DisplayLayout.GroupByBox.Hidden = true;
grdDiaryItems.DisplayLayout.Override.GroupByColumnsHidden = DefaultableBoolean.False;
grdDiaryItems.DisplayLayout.Override.HeaderPlacement = HeaderPlacement.RepeatOnBreak;
My grid layout is as follows. "Folder A" and "Folder B" are GroupByRows on the column "FolderName"
band = grdDiaryItems.DisplayLayout.Bands[0];
band.SortedColumns.Add("FolderName", false, true);
Folder A
         Date              Note
         10/09/2016          This is line one of the text
         11/12/2015          This is line two of the text
         05/02/2016          This is line three of the text
Folder B
         Date              Note
Currently when the user clicks on the Date column header of "Folder A", the rows under "Folder B" are also sorted in date order. Similarly when
the Note column header of "Folder A" is clicked, the rows under "Folder B" are also sorted.
What I want is the sorting to occur ONLY within the Folder (GroupByRow) which the clicked column header belongs to
Any help would be much appreciated
Regards
Shaz
  • 210
    Suggested Answer
    Hi Shaz,
    At this current time there is unfortunately no way to do this. As such it is a new feature idea. You can submit your idea at http://ideas.infragistics.com.
    Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it.  You can also link back to this thread for additional details.
    Thank you in advance to submitting your product idea.
    Ari Shaposhnik
