275
Fill UltraCombo with only DisplayValue and NOT ValueMember
I want to "fill" an ultracombo so a grid can be populated based on the ValueMember that is choosen from. Here's the following code.
public void FillCombo(){
conn = new SqlConnection(MSSQL);
cmd = new SqlCommand();
cmd.Connection = conn;
conn.Open();
cmd.CommandType = CommandType.Text;
cmd.CommandText = @"SELECT RTRIM(NOMBRE_ESQUEMA) as NOMBRE_ESQUEMA, ESQUEMA FROM dbo.COMISIONES_ESQUEMAS;";
MyReader = cmd.ExecuteReader();
DataTable dt = new DataTable();
dt.Load(MyReader);
if (dt.Rows.Count > 0){
this.eucEsquema.DataSource = dt;
this.eucEsquema.DisplayMember = "NOMBRE_ESQUEMA";
this.eucEsquema.ValueMember = "ESQUEMA";
conn.Close();
cmd.Dispose();
The problem here is that whenever I click the ultracombo box, both DisplayMember and ValueMember appears and I only want the user to see the DisplayMember. I don't want them to actually see the ValueMember cause if they do, maybe they'll get confused.
NOTE: I want the ValueMember to be available, but not displayed on the ultracombo box
Is there a way to achieve this?
