280
UltraTrackBar Thumb moves when the cell loses focus
I'm using VB.Net 2013 with v2016.1 of the UltraWinGrid with 2 cells that have the UltraTrackBare as the editor.  We have implemented these track bars to allow the user to tell us the start position and length of a line segment and we control the Min and Max values to prevent overlapping segments along the line.
The problem I am seeing is that when the length trackbar cell loses focus the Thumb is moving from the location that indicates the current length of the line to what looks like the Min value for the Trackbar.  But when the cell receives focus again the Thumb returns to the correct location.  I'm sure that I probably have some code that is causing this behavior but I've not found anything yet.
Has anyone else seen this or similar behavior on the TractBar?
Jamie
