140
interactive layout w/ constraints
I'm new to infragistics and somewhat new to C# and am trying to implement an interface similar to the igoogle web page using winforms.  My questions are:
I am using the WinDockManager and have disabled docking and enabled floating..
1) How do I turn off the icon (circle w/ a line that indicates docking is disabled) that displays when the pane is dragged to the edge?
2) Is there some way to combine a gridbaglayout manager with the windockmanager so the floating panes don't overlap and are constrained within the application window?
 OR,
3) Is there is some way to select and drag a pane in a gridbaglayoutpanel to another cell in the layout panel besides overriding the mouse selection and move events?
thanks,
lsr
  • 44743
    I'm not sure the UltraDockManager would be the right component to use here:
    This is not currently possible. You can submit a feature request for this: http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
    No. The dock manager isn't really meant to provide that kind of interface.
    There is no runtime support for rearranging controls within a grid bag layout panel.
    I think you will have to do a lot of custom work no matter which route you take, but you will probably be better off starting with an UltraExplorerBar with multiple columns than starting with an UltraDockManager.
