We downloaded the upgrade for Infragistics 2016.1 and installed it on our PCs. We have a license for each PC. We installed it on our Visual Studio 2013 TFS build server. We checked out everything from the two projects. We ran the update utility on our project which is part of a TFS solution. We only ran the upgrade utility on the two subprojects that we want to update at this time. We checked the two projects into TFS. We deleted the old versions of the Infragistics controls from the directory where the executables are on the target machine. The executable on the target machine will only run if we run it from a machine that has the 2016.1 version of Infragistics installed. I don't know if it will help, but here is the error message we get:
Application: AcisWorkstation.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileLoadException
Stack:
at AcisWorkstation.CustomMessage.ShowCustomMessage(System.String, CustomMsgSeverity, CustomMsgOption, Int32, Boolean)
at AcisWorkstation.My.MyApplication.MyApplication_UnhandledException(System.Object, Microsoft.VisualBasic.ApplicationServices.UnhandledExceptionEventArgs)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.raise_UnhandledException(System.Object, Microsoft.VisualBasic.ApplicationServices.UnhandledExceptionEventArgs)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnUnhandledException(Microsoft.VisualBasic.ApplicationServices.UnhandledExceptionEventArgs)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(System.String[])
at AcisWorkstation.My.MyApplication.Main(System.String[])
Hi Travis,
The exception does not tell a lot and certainly I do not connect it specifically to Infragistics assembly, but most likely you are still deploying an old assembly on the target machine or do not deploy it at all and that is why a file load exception is thrown. Furthermore, you can give it a try by taking two actions: set the specific version property for all assemblies to false and ensure that the license file is empty before building the project on the server.
Looking forward to hear from you.
Also we did copy the DLLs and XMLs to the directory where the executables are on the target machine.
