Hi,I am using 2013 view style for the Ribbon control.The issue I am facing is it looks good when the monitor display is in smaller mode(100%) but when it is set to Medium mode the upper border of Ribbon area above ribbon tab item getting disappeared.Please refer to the attachment for the details.
Sijo,
Thank you for providing your version number. A fix for this bug was made in 14.1, and at the time 13.2 was out of maintenance in accordance with our Product Lifecycle. You will need to upgrade to 14.1 or later in order to receive this fix, as there is no workaround.
We recommend upgrading to the latest volume (16.2 as of this post) to benefit from this and any other improvements or features added or to be added to the controls suite.
Hi John,
Thank you for your response. Your sample code shows exactly the same issue I have described when I run it in my environment.
I am using Infragistics version 13.2.20132.2023 in my project.So I suppose this can be an issue related to this version,would like to know,if that is the case is there any work around for this?
Hello Sijo,
For me, the behavior that you show for "medium" mode, the tab area background not showing above the tab, is the default behavior I get for "small" or "medium" modes.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using. My test was performed using version 16.2.2016.1000 in Infragistics 16.2.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Please let me know if I can provide any further assistance.
