225
Retain data of TemplateAddRow without adding the row to the ultragrid.
We have an ultraGrid with a templateAddRow on the top. When we click on a cell a row, we can edit it. In the last column of the TemplateAddRow, we added a button "+". If the user clicks on the button "+" or presses ENTER , the row is added to the grid after validating obligatory fields. Else, the data of templateAddRow is retained.
I tried with this code :
"private void UltraGridIndexOnBeforeRowUpdate(object sender, CancelableRowEventArgs e)
    if (e.Row.IsAddRow && !_canAddRow)
        ultraGridIndex.RowUpdateCancelAction = RowUpdateCancelAction.RetainDataAndActivation;
    else
        ultraGridIndex.RowUpdateCancelAction = RowUpdateCancelAction.CancelUpdate;
    e.Cancel = !_canAddRow;
_canAddRow is a boolean which value is true when the button "+" or ENTER is pressed.
This code retains data of TemplateAddRow, but disables editing of the existing rows.
Any Ideas?
Thank you in advance.
Parents Reply Children
No Data
