North American Sales: 1-800-231-8588
Global Contacts
My Account
Menu
North American Sales: 1-800-321-8588
My Account
Sign In/Register
Design & Development
Design & Develop
Best Value
Infragistics Ultimate
The complete toolkit for building high performing web, mobile and desktop apps.
Indigo.Design
Use a unified platform for visual design, UX prototyping, code generation and application development.
Web
Ignite UI for Angular
Ignite UI for JavaScript
Ignite UI for React
Ultimate UI for ASP.NET
Indigo.Design
Desktop
Ultimate UI for Windows Forms
Ultimate UI for WPF
Prototyping
Indigo.Design
Mobile
Ultimate UI for Xamarin
Ultimate UI for iOS
Ultimate UI for Android
Automated Testing Tools
Test Automation for Micro Focus UFT: Windows Forms
Test Automation for Micro Focus UFT: WPF
Test Automation for IBM RFT: Windows Forms
UX
Indigo.Design Desktop
Collaborative prototyping and remote usability testing for UX & usability professionals
Indigo.Design
A Unified Platform for Visual Design, UX Prototyping, Code Generation, and App Development
Business Intelligence
Reveal Embedded
Accelerate your time to market with powerful, beautiful dashboards into your apps
Reveal App
Empower everyone in your organization to use data to make smarter business decisions
Team Productivity
Learn & Support
Support
Help & Support Documents
Blogs
Forums
Product Ideas
Reference Applications
Customer Stories
Webinars
eBook & Whitepapers
Events
Free Trials
Pricing
Product Pricing / Buy Online
Renew Existing License
Contact Us
Forums
Your Privacy Matters
: We use our own and third-party cookies to improve your experience on our website. By continuing to use the website we understand that you accept their use.
Cookie Policy
Close
State
Not Answered
1 reply
Subscribers
6 subscribers
Views
Users
0 members are here
Documents Library
Share
More
Cancel
610
Documents.Excel.Worksheet.Save Method Generates Exception
Jarid Griesel
over 7 years ago
After exporting an UltraGrid with a large number of cells, (8 columns, +- 200 000 rows) to
an Infragistics.Documents.Excel.Workbook, using an UltraWinGrid.ExcelExport.UltraGridExcelExporter
the Excel.Workbook.Save(string FileName) method is called which fails with an Exception with the message
"Unable to identify the identity of domain.
The resulting workbook file on disk is only unrecognisable to MS Excel.
Excel returns HRESULT: 0x800A03EC when Excel.Application.Workbooks.Open(String Filename) is executed.
This issue started with Infragistics Build no 2016.2
This issue was not present in Infragistics Build no 2016.1.20161.2033
Program Code
Imports Infragistics.Documents
Dim loWorkBook As New Excel.Workbook
Dim loWorkSheet As New Excel.Worksheet
Dim loExporter AS New UltraWinGrid.ExcelExport.UltraGridExcelExporter
loWorkBook.SetCurrentFormat(Excel.WorkbookFormat.Excel2007)
With loWorkBook.Worksheets
.Clear()
loWorkSheet = .Add(pcWSName)
End With
loExporter.Export(myUltraGrid, loWorkSheet, 1, 1)
loWorkBook.Save("c:\temp\test.xlsx")
Exception Message
System.IO.IsolatedStorage.IsolatedStorageException: Unable to determine the identity of domain.
at System.IO.IsolatedStorage.IsolatedStorage._GetAccountingInfo(Evidence evidence, Type evidenceType, IsolatedStorageScope fAssmDomApp, Object& oNormalized)
at System.IO.IsolatedStorage.IsolatedStorage.GetAccountingInfo(Evidence evidence, Type evidenceType, IsolatedStorageScope fAssmDomApp, String& typeName, String& instanceName)
at System.IO.IsolatedStorage.IsolatedStorage._InitStore(IsolatedStorageScope scope, Evidence domainEv, Type domainEvidenceType, Evidence assemEv, Type assemblyEvidenceType, Evidence appEv, Type appEvidenceType)
at System.IO.IsolatedStorage.IsolatedStorage.InitStore(IsolatedStorageScope scope, Type domainEvidenceType, Type assemblyEvidenceType)
at System.IO.IsolatedStorage.IsolatedStorageFile.GetStore(IsolatedStorageScope scope, Type domainEvidenceType, Type assemblyEvidenceType)
at MS.Internal.IO.Packaging.PackagingUtilities.ReliableIsolatedStorageFileFolder.GetCurrentStore()
at MS.Internal.IO.Packaging.PackagingUtilities.ReliableIsolatedStorageFileFolder..ctor()
at MS.Internal.IO.Packaging.PackagingUtilities.GetDefaultIsolatedStorageFile()
at MS.Internal.IO.Packaging.PackagingUtilities.CreateUserScopedIsolatedStorageFileStreamWithRandomName(Int32 retryCount, String& fileName)
at MS.Internal.IO.Packaging.SparseMemoryStream.EnsureIsolatedStoreStream()
at MS.Internal.IO.Packaging.SparseMemoryStream.SwitchModeIfNecessary()
at MS.Internal.IO.Packaging.SparseMemoryStream.Write(Byte[] buffer, Int32 offset, Int32 count)
at MS.Internal.IO.Zip.ZipIOFileItemStream.Write(Byte[] buffer, Int32 offset, Int32 count)
at System.IO.Compression.DeflateStream.WriteDeflaterOutput(Boolean isAsync)
at System.IO.Compression.DeflateStream.InternalWrite(Byte[] array, Int32 offset, Int32 count, Boolean isAsync)
at System.IO.Compression.DeflateStream.Write(Byte[] array, Int32 offset, Int32 count)
at MS.Internal.IO.Packaging.CompressStream.Write(Byte[] buffer, Int32 offset, Int32 count)
at MS.Internal.IO.Zip.ProgressiveCrcCalculatingStream.Write(Byte[] buffer, Int32 offset, Int32 count)
at MS.Internal.IO.Zip.ZipIOModeEnforcingStream.Write(Byte[] buffer, Int32 offset, Int32 count)
at System.IO.BufferedStream.Flush()
at System.IO.StreamWriter.Flush(Boolean flushStream, Boolean flushEncoder)
at System.IO.StreamWriter.Dispose(Boolean disposing)
at System.IO.StreamWriter.Close()
at System.Xml.XmlTextWriter.Close()
at System.Xml.XmlWriter.Dispose(Boolean disposing)
at System.Xml.XmlWriter.Dispose()
at Infragistics.Documents.Core.Async.UsingHelper`1.<Execute>b__b()
at Infragistics.Documents.Core.WorkItem.WorkItemSync.ExecuteCore(WorkItemScheduler scheduler)
at Infragistics.Documents.Core.WorkItem.Execute(WorkItemScheduler scheduler)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at TryThrowExceptionDispatchInfo(Object )
at Infragistics.Documents.Core.WorkItem.ExceptionInfo.Rethrow()
at Infragistics.Documents.Core.WorkItem.RethrowIfExceptional()
at Infragistics.Documents.Core.WorkItem.RunNextWorkItem(WorkItemScheduler scheduler)
at Infragistics.Documents.Core.WorkItemScheduler.SynchronousImpl.Execute(WorkItem workItem)
at Infragistics.Documents.Excel.Workbook.Save(String fileName, WorkbookSaveOptions saveOptions) at myApplication.clsExportToExcel.ExportToExcel() in myApplication\clsExportToExcel.vb:line 264
469350
Offline
Mike Saltzman
over 7 years ago
This thread is a duplicate and it answered
here
Cancel
Reply
Cancel
