229
AutoFitStyle + WrapHeaderText = column width doesn't stop changing
 Hi
 If I set the following:
ultraGrid.DisplayLayout.AutoFitStyle = AutoFitStyle.ResizeAllColumns;
ultraGrid.DisplayLayout.Bands[0].Override.WrapHeaderText = DefaultableBoolean.True;
and then click on one header cell to sort, the column widths are changing and changing and changing. never stops again. It's difficult to explain, so watch the video I took (http://imis.pog.ch/idas.avi 4MB). If I only use one of the code lines above, all works fine.
Have you any solution for that problem?
I use NetAdvantage .NET 2007 Vol. 3 CLR 2.0
Best regards
Clay
