We are trying to make our winforms app dpi aware, but we are having trouble when we use the UltraDockManager.
The areas and panes do not scale, and so everything gets crushed (for example the font increases in size for the titles, but the depth and width of the title bar has not been scaled).
Is there something I am missing, or do I need to find an alternative to the Dock Manager?
We are having the exact same issue. We have million of lines of code in Winform and we are not going to change soon.
We are doing the change to our application to make it DPI aware and so far everythign is working fine except the Infragistics controls which don't honor the DPI awarness. Very disapointing.
We may change the tool we are using though because the idea using Infragistics was to get help in these difficult situations.
Hugues
I believe that I'm not your only customer who is buying Infragistics suite mainly for maintaining older Windows.Forms applications. Neither I believe that WPF or UWP are definitely The Way when it comes to desktop development: sure it might be, but before facing huge porting projects for very complex LOB applications, any investment must be very carefully planned. So this is why Windows.Forms is still not playing a side role in desktop development, and in this field, DPI awareness is a major theme.
Maybe we are all 'victims' of MS strategy, but when I read from Infragistics R&D that "none of our controls are DPI aware", I feel that the money spent by your Windows.Forms customers in renewing their subscriptions is wasted.
With the exception of the UltraLiveTileView, none of our controls are DPI aware. As such, the options are to either allow the .NET framework to perform the scaling for you (which tends to paint the form with blurry rendering due to the scaling), or to mark the application as DPI aware, and perform the scaling manually. I'll use a bulleted list in hopes of avoiding missing an issue:
I hope this helps to clarify some of these issues.
Chris
>The Debug output you have provided shows that controls (not just Infragistics controls, but all design-time generated controls) are being scaled.
The left pane and the right pane width didn't scale correctly as you can see in the output. It's a shame because, as you have observed, the rest of the controls are being scaled.
Please add that to Robin's list of DPI problems in the UltraDockManager.
Hi Chris,
Thanks for the reply.
Our end goal here is to make our application DPI Aware, remain functional and look beautiful.
From other threads, I believe that your UltraDockManager is not DPI Aware and therefore does not respect the AutoScaleMode property that a Framework ContainerControl would give. Please correct me if I am wrong. Therefore we need to manage the scaling ourselves.
However, whilst we can do this, from the testing we have done there are still some issues:
Robin
