295
CellActivation =.Activate.AllowEdit only working for top row in grid
If I have 2/3/4 etc rows in my UltraGrid, I've got an issue. I'm trying to allow edit of 2 columns in the active row when the date column value is changed.
The 2 cells are only editable once the top row in the grid has had a date value entered.
However, I want it to activate for the row that the date was entered on, even if the top row hasn't got a date value.
I've also tried just updating the bottom row, clicking a different control, and seeing if it works then, but it still doesn't.
Am I doing something wrong? I've tried both of the activation lines using the e.Cell.Row.Cells method, and the row.Cells method.
Try
   If e.Cell.Column.Key = "PaymentDate" Then
      e.Cell.Row.Cells("Customer_Paid").Activation = Activation.AllowEdit
      e.Cell.Row.Cells("Customer_Paid").Value = True
      row.Cells("suppInvoiceNum").Activation = Activation.AllowEdit
   End If
Catch ex As Exception
   errorLog(ex)
End Try
