365
UltraTree 'Parameter not valid' error
We are currently using an UltraTree in an application. We have a customer (that I believe is always using a remote desktop connection) that randomly experiences a "Parameter not valid" error.
Here is the stack trace:
System.ArgumentException: Parameter is not valid.
   at System.Drawing.Image.get_Width()
   at System.Drawing.Image.get_Size()
   at Infragistics.Win.EditorWithTextUIElement.GetImageSize(Image img, Size& imageSize)
   at Infragistics.Win.EditorWithTextUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)
   at Infragistics.Win.UIElement.VerifyChildElements()
   at Infragistics.Win.UltraWinTree.UltraTree.SetActiveNode(UltraTreeNode node, Boolean bringIntoView, Boolean adjustHorizontalPosition, NodeActivationReason reason)
   at Infragistics.Win.UltraWinTree.UltraTree.Infragistics.Win.ISelectionManager.ActivateItem(ISelectableItem item)
   at Infragistics.Win.SelectionStrategySingle.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo, Boolean forceDrag)
   at Infragistics.Win.SelectionStrategySingle.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo)
   at Infragistics.Win.SelectionStrategySingle.OnMouseMessage(ISelectableItem item, MouseMessageInfo& msginfo)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e)
   at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
   at Infragistics.Win.UltraWinTree.UltraTree.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
To be honest, I haven't gotten a good read on what is actually causing the error, was hoping that something would jump out given the stack trace.
I believe the following is the version of Infragistics being referenced.
11.2.20112.2050
Thanks in advance!
Steve
