90
Pivot Grid with strings as Measure
Hi I know from other olap Sytems that you can use measure also as a kind of string value output and that kind I searching for.
If I declare a measure in my flatdatastore as number like int it appair in the measure choice, if I declare a string as measure and really need that one as measure it switch to dimension and I have no measure of that kind.
Something like the one below I need and for that I really need the none numerical values as measure.
I goes more komplex with some more dimension i do plan for it but the example below should be allready show what I really need ;)
                                    Question 1 (Shift)                    | Question 2 (status)                | Guestion 3 (Person in charge)
Year:2008 Department 1| Answer 1: night Shift               | Answer 2: done| None             | Mister X
               Department 2|| Answer 1: morning shift          | Answer 2: in process               | Mister Y
               Department 3|| Answer 1: none                      | Answer 2: none                     | Mister Z
Would be very great if you could help me since I need it very much ;)
Parents Reply Children
No Data
