430
WinGrid Add with TabRepeat Problem
There is a grid where we have with AllowAddNew = TemplateOnTopWithTabRepeat.  When the last column has it's tabstop set to False, pressing the tab key takes you to the next grid row instead of the template add row at the top.
Are we missing something here?
  • 1980
    Verified Answer
    Hello md10,
    I have investigated your issue, and I have asked our engineering staff to examine the behavior of the grid's AddRow after pressing the tab key in case the last column TabStop is set to false further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of #233179. So I’ve created a case for you 181673 and will update you for the progress of this issue via the mentioned case. You could reach your case following the link below:
    https://ko.infragistics.com/my-account/support-activity
