I would like to know if it is possible to disable some items in a UltraComboEditor multi-selection ?
Regards
Thank you for your solution.Finally I will continue to work with an UltraComboEditor and try another way to simulate this behavior.
Thank you very much
Christian
Hi Pokorny,
The UltraComboEditor is not designed to allow the disabling of individual items. You can of course submit that as a feature request here, ideas.infragistics.com. That being said you can achieve this functionality using the UltraCombo. Each row in the UltraCombo has an Activation property which you can set.public enum Activation{ // Allow Edit. The grid will attempt to edit the content of the object. AllowEdit = 0, // Activate Only. The object may be selected (to copy and paste) but may not be edited. ActivateOnly = 1,
// Disabled. The object may not be activated and text may not be selected or edited. Disabled = 2,
// No Edit. The object may be activated(text highlighted), but cells cannot be edited or selected(to copy and paste). NoEdit = 3}
Let me know if that helps,
