2490
ultranumericeditor null value
I use ultranumericeditor with Nullable = true
When I erase all data, I can't assign my property because the value is not NULL is System.DBNull
_Quote.NumberDeliveryDays = (int?)uneNumberDeliveryDays.Value;
I have error 'System.InvalidCastException'
What is the best way to assign my property to NULL ?
Francois.
  • 6158
    Verified Answer
    Hello Francois.
    It is intentional that the UltraNumericEditor's Value property returns DBNull when the edit area is empty. This was most likely done to support binding to the Value property.  You should be able to work around this using a simple DBNull check:
    _Quote.NumberDeliveryDays = this.uneNumberDeliveryDays.Value == DBNull.Value ? (int?)null : (int)this.uneNumberDeliveryDays.Value;
    Additionally if there are numerous places where this scenario would be encountered, you could get around the issue using a DataFilter. This forum post gives details regarding a DataFilter of this nature.
