Hi all,
I managed to retrieve relational data (from SQL Server) via FlatDataSource and to show them in a WinPivotGrid.
Yet, some attributes in my table are mis-recognised as measures: they are integer values, but aggregating them is of no use. So, these are not measures but dimensions!
It seems to me that all numeric values are considered as measures and all not-numeric values are considered as dimensions. This is just a guess, because an experimental cast to varchar for my integer attributes caused WinPivotGrid to offer them as dimensions. Back to integers, they were offered as measures...
Is there way to influence that? It should be me who decides which field is a measure and which is a dimension. :)
Thanks for any hint.
Martin
Hello Martin,
Sure. You can contact us back if you need any assistance after upgrading.
Thank you for choosing Infragistics.
Sincerely,Sahaja KokkalagaddaAssociate Software Developer
Hello Sahaja,
the IT department won't let me install this on my own. And introducing a new version of any software here is quite an ordeal :)
So, I'm stuck for now.
I'm gonna ask the IT guys. Maybe this new version will come true for my Company in this life. *g*
Thanks for your patient help.
Regards
I tested the PivotGrid sample using 16.1.1000 build and observed some performance lag. However, the steps I followed are a bit different. I was able to drag the dimensions with no trouble but I’m not able to expand them. I did not reproduce this issue using 16.1 SR though. My recommendation for resolving this issue is to get 16.1 SR (16.1.20161.2118) and see if that resolves this issue.
If you have a 16.1 key then the SR download link can be found in your MyKeysandDownloads page when you log into your account at Infragistics.com.
Please try the above suggestion and let me know if I may be of further assistance.
it must be the DLLs:
I've got the 16.1 versions, so I had to switch all references in your project to my 16.1-dlls. Then it compiled, but showed the same problems in your project as I had in my approach.
Do you have a 16.1 version at hand to reproduce my issue? Maybe I can convince our IT dept to upgrade to 16.2, but this takes nearly as long as the eternal loop in my form :D.
Thanks and have nice weekend.
PS: Exact Version as in object Explorer: System.Reflection.AssemblyFileVersionAttribute("16.1.20161.1000"),
Hi Martin,
I followed the steps you suggested and was unable to reproduce the behavior you're describing. I changed the type of DimentionA which in my sample is Sports to both integer and string and did not observe any performance lag in both scenarios.I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.I have used an enumerable list as my DataSource as you mentioned fetching data is taking only two seconds. So I assumed this is not related to the DataBase and used a simple FlatDataSource sample.If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using. My test was performed using version 2016.20162.1000 in Infragistics for WindowsForms 2016 Vol2.If this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back.
Please let me know if I can provide any further assistance.
