I have a UltraWinTree with the ViewStyle property set to Standard.
When it displays the tool tip, it looks a little blurry and bold.
I have attached a file with a .png image.
ToolTips in my other controls look fine. It just this control that it looks strange.
We do have a style set for this control, but it is the same style as the other controls with tool tips.
Is there some setting, that I am missing that is causing this to happen?
Sorry it took so long to respond to this, but I have been working on other things.
I do not have a sample, but I know what the problem is.
The ToolTip will look Bold\Blurry if you you set the UltaTree Display style in the Infragistics Components of the style file to "WindowsVista"
I was able to reproduce this by creating a style from one of the Templates (Template_Glassy.isl).
The only change I made to the template was to set the Display style for the UltraTree to WindowsVista.
Harlan
Hello,??
This could be caused by a style or another setting in the application. Can you send the style so I can test it, or a reproduction sample that I can use to debug?
