215
Ultra Grid Group by
Hi
I have an ultragrid which I allow group by on.  I also allow updating, deleting and inserting which gives me a null reference error.  I'm not sure why and I've considered disabling the buttons on the group by event which I was able to do (example a).  But when the group by is turned off how is there a better way to trap that?
Is it common practive to NOT allow Insert/Update/Delete when grouping?  If so, Is there a better way to disable it?
Example A)
private void UltraGridList_AfterSortChange(object sender, BandEventArgs e)
            //isGroupBySet = false;
            //for (int i = 0; i < e.Band.SortedColumns.Count; i++)
            //    UltraGridColumn sortColumn = e.Band.SortedColumns[i];
            //    if (sortColumn.IsGroupByColumn)
            //        isGroupBySet = true;
            //if (isGroupBySet == true)
            //    btnInsert.Enabled = false;
            //    btnDelete.Enabled = false;
            //    this.UltraGridList.DisplayLayout.Override.AllowUpdate = DefaultableBoolean.False;
            //else
            //    btnInsert.Enabled = true;
            //    btnDelete.Enabled = true;
            //    UltraGridList.Enabled = true;
            //    this.UltraGridList.DisplayLayout.Override.AllowUpdate = DefaultableBoolean.True;
