I'm adding buttons runtime to the ribben. However the buttons for the ApplicationMenu on the left side are all disabled. I cannot figure out why and how I can enabled these buttons.
See below the part where the button/tools are added:
Great! Glad you uncovered the problem. Have a good day.
Chris
Hi Cris,
I tested the sample and it works fine.
We looked further in our application and found the problem. Another function was disabeling all the tools in the ribbon after we added the tools for application menu.
Thanks for the help.
Hello Ronald,
I don't foresee any reason for these tools to not be enabled. I've added your code to a sample application, and the tools are enabled and responsive. I've attached the sample for your inspection. Please run the sample and verify the behavior. When you run it, if the tools are enabled in this sample, please attempt to modify the sample to match your application in hope of reproducing the issue.
Thank you.
