315
WinPivotGrid - can modify caption for column or row
I use FlatDataSource to bind data to WinPivotGrid.
I would like to set caption for column attributes (now it is the same with the name of colums from datasource)
Please help.
  • 7695
    Verified Answer
    You would want to handle the Initialize Descriptor events.
    InitializeOlapAxisElementDescriptor to customize the Dimensions names
    InitializeHierarchyDescriptor to customize the "All " caption names
    InitializeMeaureDescriptor to customize the Measures settings, including how it aggregates and format strings
    There is demostrations of the Hierarchy and Measure customizations in the samples browser, with a code snippet available here:
    https://ko.infragistics.com/samples/windows-forms/pivot-grid/pivot-grid-binding-to-flat-data
    With the OlapAxisElement customization example is here:
    private void Ds_InitializeOlapAxisElementDescriptor(object sender, InitializeOlapAxisElementDescriptorEventArgs e)
     switch (e.OlapElementDescriptor.Name)
      case "Nation":
       e.OlapElementDescriptor.Caption = "XXXX";
       break;
      default:
       break;
    Let me know if that helps,
