When in the report I do not have Row attribute, WinPivotGrid does not present the measure values in Grid.
The same thing happens when I select only Column without Row,WinPivotGrid does not present the measure values in Grid.
Hello Iacos,
Our developer has finished reviewing WinPivotGrid does not present the Measures values when Row attribute is not defined issue. He confirmed that this is the default behavior of the control. When no row or column attributes are specified then the OLAP framework will not give any cells. I.e If there are no rows or columns then there are no cells.
We are closing the development issue linked to case(CAS-184499-W4T2N9) at this time. Please let me know if I may be of further assistance.
Sincerely,Sahaja KokkalagaddaAssociate Software Developer
Is there any workaround which can be made?
Can I add a virtual row if there is not set a row, or a virtual column if it is not set?
How can I add a row runtime to a FlatDataSource. I fill the FlatDataSource using an SQL script, but If it is posiible, I don't want to modify the script.
I prefeare to modify the FlatDataSource after it is fill-ed in using an SQLAdapter.
Can you help me, how is it possible?
I have investigated WinPivotGrid does not present the Measures values when Row attribute is not defined issue, and I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 238140. This will be assigned to a developer in a future sprint to review my investigation and confirm my findings or to offer a fix, or other resolution. I will update you with any new information after the review.
I have created case CAS-184499-W4T2N9 to track the status of this development issue.
You can view the status of this development issue by selecting the "Development Issues" tab when viewing this case on the web site.
Please let me know if you need more information.
