570
UltraPopupControlContainer closed event not firing modal dialog
I have a UltraPopupControlContainer on a modal dialog.
If I click on the modal dialog the UltraPopupControlContainer is on, the control will close.
However if I click anywhere else on my application or outside of the application, the container closed event does not get fired and control stays visible.
Is this because it is on a model dialog?
Is there a way I can get the control to close when clicking outside of the dialog?
Harlan
  • 21795
    Hello Harlan,
    This issue was fixed and fix was included in our latest service release for version 16.2 and 17.1. The fix is also included in all feature version of Infragistics for Windows Forms.
  • 21795
    Hi Harlan,
    This issue has been fixed and verified internally by our Engineering Team. The service release containing the fix will be published according to following schedule:
    http://ko.infragistics.com/support/service-releases/
  • 21795
    Hello Harlan,
    I have investigated your issue, and I have asked our engineering staff to examine why UltraPopupControlContainer form does not close when user clicks on other form further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of #238045. So I’ve created a case for you CAS-184543-P8B9Q3 and will update you for the progress of this issue via the mentioned case. You could reach your case following the link below:
    https://ko.infragistics.com/my-account/support-activity
