Hi All,
I am trying to implement the feature of zooming the ultradayview control i.e. to increase the width between the time slots.Can anyone tell for implementing this feature in C# .
Thanks in advance .
Is this still accurate? Is there no "good" way to change the number of pixels between timeslots?
If I go the route of changing the font, which appearance do I change the font on? Can I tell programmatically the height in pixels of the timeslot after changing the font size?
Dave
The only way to do any sort of "zooming" or to affect the size/height of the timeslot elements is to adjust the Font size of the ultradayview.
Probably NOT what you need but... The only other way of achieving the "appearance/illusion" of zooming is to decrease your timeslotinterval... eg: with timeslot interval set to 60mins, a single hour long appointment looks quiet small... but when you set it to 10 minute intervals, the appointment will appear 6 times larger on screen.
Kind RegardsAaron
