When i use UltraMonthViewMulti i want change Day cells BackColor.
How can i change?
if there is a way...can you give me some example code?
Hi Dong-wook,
You can find code snippet and sample regarding your question at the following forum threads:
https://ko.infragistics.com/community/forums/t/109078.aspx https://ko.infragistics.com/community/forums/t/80975.aspx
Let me know if you need further assistance regarding this matter.
