2150
ArgumentException from System.Drawing.Graphics.GetHdc()
I have a WPF application that does some integration with legacy Infragistics/winforms.
On a fairly regular basis we get fatal exceptions that are sent out from the depths of an Infragistics call stack.  They are "ArgumentExceptions" from System.Drawing.Graphics.GetHdc() - which is typically called from some Infragistics component, eg (Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureTextGDIOrThemed(String text, Font font, TextFormatFlags textFormatFlags).
My recollection is that IG does some internal caching of win32 Device Context information and it misbehaves in certain circumstances.  Are there any tips you can give us for making this stuff work in a more reliable way?  I have already tried including this magical method call in a number of places: Infragistics.Win.DrawUtility.BeginGraphicsCaching()  ...
... but that doesn't seem to fully fix the problem.  It would be nice if the exception had more information for us to use in our troubleshooting, or if these winforms controls could do a better job at recovering from their own internal problems with their own cached data.
Below is an example of a full stack trace.
Application: UFP.LumberTrack.Production.Mill.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ArgumentException
at System.Drawing.Graphics.GetHdc()
at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureTextGDIOrThemed(String text, Font font, TextFormatFlags textFormatFlags)
at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureCharacterRangesGDI(String text, Font font, TextFormatFlags textFormatFlags, CharacterRange[] ranges)
at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.ReMeasureParts(String text, Int32[] parts, Single[] widths, Int32 partStartIndex, Int32 partEndIndex, Font font, Single& lineHeight)
at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureParts(String text, Int32[] parts, Font font, Single& lineHeight)
at Infragistics.Win.FormattedLinkLabel.NodeText.TextLayoutInfo.Measure(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeText.PositionSelf(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBase.PositionHelper(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBase.PositionChildNodes(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBlock.PositionChildNodes(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBase.CalcSize(IFormattedLinkLabelOwner owner, Graphics graphics, Int32 maxWidth)
at Infragistics.Win.UltraWinToolbars.Ribbon.RibbonMetrics.CalculateCaptionAreaHeight()
at Infragistics.Win.UltraWinToolbars.Ribbon.RibbonMetrics.GetRibbonHeight(Boolean isAutoHideRibbonPopup)
at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.RefreshDockAreaSize(Size& currentSize)
at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.SetBoundsCore(Int32 x, Int32 y, Int32 width, Int32 height, BoundsSpecified specified)
at System.Windows.Forms.Control.System.Windows.Forms.Layout.IArrangedElement.SetBounds(Rectangle bounds, BoundsSpecified specified)
at System.Windows.Forms.Layout.DefaultLayout.xLayoutDockedControl(IArrangedElement element, Rectangle newElementBounds, Boolean measureOnly, Size& preferredSize, Rectangle& remainingBounds)
at System.Windows.Forms.Layout.DefaultLayout.LayoutDockedControls(IArrangedElement container, Boolean measureOnly)
at System.Windows.Forms.Layout.DefaultLayout.xLayout(IArrangedElement container, Boolean measureOnly, Size& preferredSize)
at System.Windows.Forms.Layout.DefaultLayout.LayoutCore(IArrangedElement container, LayoutEventArgs args)
at System.Windows.Forms.Layout.LayoutEngine.Layout(Object container, LayoutEventArgs layoutEventArgs)
at System.Windows.Forms.Control.OnLayout(LayoutEventArgs levent)
at System.Windows.Forms.ScrollableControl.OnLayout(LayoutEventArgs levent)
at System.Windows.Forms.Form.OnLayout(LayoutEventArgs levent)
at System.Windows.Forms.Control.PerformLayout(LayoutEventArgs args)
at System.Windows.Forms.Control.PerformLayout()
at System.Windows.Forms.Control.ResumeLayout(Boolean performLayout)
at UFP.LumberTrack.Shared.Windows.Forms.UfpBaseForm.Show(Form p_Parent)
at UFP.LumberTrack.Production.Presentation.AppLaunchers.InventoryControlLauncher.LaunchInventoryControl(IProvideParentForWindow ParentForWindow, String p_ActiveBranchCode, String p_AppServerProUserName, String p_ProductType, String p_ProductCode, Boolean p_UseSpecificLengthCode, String p_LengthCode)
at UFP.LumberTrack.Production.Kiln.Workspace.Sources.Viewers.InventoryLevelItemSelection.ExecuteShowInventoryControl(IInventoryManagementItem p_Item)
at UFP.LumberTrack.Production.Kiln.Workspace.Sources.Viewers.InventoryLevelItemSelection.DataRecordPresenter_MouseDoubleClick(Object p_Sender, MouseButtonEventArgs p_Args)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Controls.Control.HandleDoubleClick(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at UFP.LumberTrack.Production.Mill.MfgManagement.MfgProgram.Main()
