20
UI Glitch during Infragistics 10 Upgrade from Infragistics 2 version.
Project Type          : Windows Forms Application using VS 2017
Original Project     : DotNet 3.5 and Infragistics 2
Upgraded Project :  DotNet 4.5.2 and Infragistics 10.2
After upgrading the Project to Infragistics 10.2, backcolour of the disabled Infragisics UltraTextEditor control is different as in the attached Picture, this case is same throughout the project for all forms.All controls which have Enabled=False, have a blue background however after version 10.2 the background is grey
Is there any configuration change available to modify this Text Control UI property that will reflect throughout the project?
  • 4625
    Hi Karthikeyan,
    Welcome to our forums!
    In order to apply and maintain easily appearance through all controls in specific project, you can use our application styling extension for Windows Forms. Great start to get familiar with it is through our documentation help at https://ko.infragistics.com/help/winforms/styling-guide-getting-started
    UltraFormattedText editor has disable background appearance. Either you can change it through code behind or through the aforementioned styling extension, which is called AppStylist for Windows Forms and it is installed along with the controls set.
    When you create your specific style library matching your visual requirements, you can save it as .ISL filename, which is just XML file. The final step would be to load that ISL file and the right way to do it is described at https://ko.infragistics.com/help/winforms/styling-guide-loading-a-stylelibrary
    Let me know if you need further assistance regarding this matter.
