We are trying to enable our application for high-DPI displays, and have run into a problem.
When using an AppStylist style, the width of the drop down button (and the associated image) are different in UltraTextEditor with a DropDownEditorButton than they are in the UltraCombo and UltraComboEditor. Even at 96 DPI, the widths are different, but not by much so not very noticeable. Under high DPI settings, the difference is much bigger and definitely noticeable.
The attached sample demonstrates the problem using the stock Office2007Blue.isl style sheet.
How can we correct this so that all the drop-down buttons appear the same width, and their drop-down arrow image appears the same size?
Hi Chris,
I will install the next official service pack after it is released. Thank you very much for your quick answer.
Best regards Frank
Hey Frank,
We have already addressed this issue internally in versions 2017.1 and 2017.2. So as long as you have a registered key, we can send you a link to the private patch with the fix. Simply create a new support case, referencing this forum thread, and we'll go from there.
As far as a workaround goes, the best option I foresee is simply replacing the existing DropDownButton of the UltraCombo/UltraComboEditor, with a DropDownEditorButton in the ButtonsRight collection. The editor buttons have a Width property that you can set once you determine the DPI. The following code works well in my sample:
private float scalingFactor;
private void Form1_Load(object sender, EventArgs e)
using (Bitmap bmp = new Bitmap(1, 1))
using (Graphics g = Graphics.FromImage(bmp))
scalingFactor = g.DpiX / 96f;
this.ReplaceDropDownButton(this.ultraComboEditor1);
this.ReplaceDropDownButton(this.ultraCombo1);
private void ReplaceDropDownButton(UltraComboEditor comboEditor)
comboEditor.DropDownButtonDisplayStyle = Infragistics.Win.ButtonDisplayStyle.Never;
var newButton = new DropDownEditorButton();
newButton.Width = (int)(EditorWithComboDropDownButtonUIElement.defaultDropDownButtonWidth * scalingFactor);
newButton.Click += (p1, p2) =>
comboEditor.DropDown();
comboEditor.ButtonsRight.Add(newButton);
private void ReplaceDropDownButton(UltraCombo combo)
combo.DropDownButtonDisplayStyle = Infragistics.Win.ButtonDisplayStyle.Never;
combo.PerformAction(UltraComboAction.Dropdown);
combo.ButtonsRight.Add(newButton);
Let me know if you have any questions,
Chris
This is an image cut from a camera dialog.
We have been running into the same problem. We have observed if the UltraCombo/UltraComboEditor is set to Standard and AppStyling is not activated the width of the DropDownEditorButton does follow to the width of the VerticalScrollbar. But if AppStyling is activated, the width of the DropDownEditorButton is 14 pixels. Our customers are more and more using 4K displays and therefore we please need to have a workaround for this. If we could overwrite the width of the DropDownEditorButton at runtime it would help a lot.
Thank you very much indeed.
Hello Scott,
We had a number of discussions among the engineering staff about what how the DropDownEditorButton should be sized by default. In the end, we came to the conclusion, that we'd prefer the width of the DropDownEditorButton matches the width of the EditorButtons, instead of attempting the match the DropDownButton.
In any case, the workaround to get the DropDownEditorButton to match the DropDownButton (setting the Width property to 14) is pretty straightforward.
