i'm trying to use the UltraCode128Barcode-Control to display Barcodes. But unfortunately it's not working.
I've tried to realize this solution with different attributes. I tried it with UltraCode128Barcode control as well as by creating it manually by adding a Barcode() to the form.
I need to create Code128CodeType.Standard.
1.
/* http://help.infragistics.com/Help/Doc/WinForms/2016.1/CLR4.0/html/xamBarcode_Adding_Barcode_In_Code_Behind.html
var Barcode = new UltraCode128Barcode();
Barcode.Data = "(01)00653216546543";
Barcode.CodeType = Infragistics.Win.DataVisualization.Code128CodeType.Standard;
this.Controls.Add(Barcode);
2.
ucb_Barcode.Data = "000000001236";
Can you please tell me how to get this barcode generation working with Infragistics?
Thanks in advance,
Jan
Yes, the article I was looking for. Your article gives me another approach on the subject. I hope to read more articles from you.wings io
Oh yes the problem i need to find. Your article provides useful information that i am looking for. I will often visit this site.
ABCYA
Thanks for the help, i will try to fix it
Hi Mike,
the code was not generated. But we got it working now. Problem was that we set the data for barcode control in constructor. Once I use a button click and set data again the control is working. Maybe this has some paint or initializeComponents issue.
Thank you for your support.
Alex
Hi Jan,
What, exactly, is "not working?"
I tried this out and it works fine for me. I have attached a small sample project using the code you posted here and it works for me. I am attaching my sample project here so you can take a look.
