We were on a really old version of Infragistics (11.2) and we recently upgraded to 16.1.
In the latest version, we found that we are getting an exception with the following code:
private void ut_Click(object sender, EventArgs e) { UltraTree utControl = (UltraTree)sender; if (utControl.ActiveCell == null) return;
switch (utControl.ActiveCell.Column.Key) { case "Checked": utControl.ActiveCell.AllowEdit = AllowCellEdit.Full; utControl.ActiveCell.BeginEdit(); if ((CheckState)utControl.ActiveCell.Value == CheckState.Unchecked || (CheckState)utControl.ActiveCell.Value == CheckState.Indeterminate) utControl.ActiveCell.Value = (int)CheckState.Checked; else if ((CheckState)utControl.ActiveCell.Value == CheckState.Checked) utControl.ActiveCell.Value = (int)CheckState.Unchecked;
utControl.ActiveCell.EndEdit(false); utControl.ActiveNode.Update();
Here's the stack trace:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.NullReferenceException: Object reference not set to an instance of an object. at Infragistics.Win.UltraWinTree.UltraTreeNode.CommitCellValues() at Infragistics.Win.UltraWinTree.UltraTreeNode.Update() at OptiGlass.ctlOptimizer.ut_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at Infragistics.Win.UltraControlBase.OnClick(EventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I did a
Not sure if we're doing something that was OK in 11.2 but is no longer OK in 16.1 or if this is a bug, but I wasn't able to find any information on this.
Thanks in advance!
Steve
You are correct, we're on 2016.1, so that explains it, thanks.
Hi Steve,
The installer is a patch for v2017.1. Do you have that version installed? I think you original said that you were upgrading to 2016.1. The fix is only available in 2017.1 and up. We are no longer updating any older versions.
Mike, I downloaded the service release in the case, but I get an error trying to run it "The upgrade patch cannot be installed by the Windows Installer service because the program to be upgraded may be missing, or the upgrade patch may update a different version of the program...", so I have no way to verify the fix.
All that said, we've worked around it so we're not necessarily in a rush, but I can't verify the fix either for you guys.
Thanks Mike, we'll take a look, appreciate it!
A fix for this issue has been released and you will receive an update via the support page with a link to download the fix.
