When I try to export Pivot data to excel the attached errors are coming (Code is copied from your site only). Pls help me. Is there any control to do it easily.
Jims
Hello Varghese,
By default the samples are installed in “C:\Users\Public\Documents\Infragistics\2017.1\Windows Forms\Samples” folder. In the installation folder you can find all the sample projects. The ones you are asking about are in Extensions subfolder.
From where we will get these libraries you mentioned.
Did you copy the code from the sample and paste it in your project? If this is what you did it will not work. All samples in Infragistics Samples Browser depends on some libraries, e.g. PivotGridDemo depends on Infragistics.Extensions.Portable and on Infragistics.Extensions.Platform.
However, the main question here is what you are trying to achieve. If you need to export UltraPivotGrid to MS Excel this is not supported now in UltraPivotGrid control. You can suggest this as new feature idea for future versions by emailing ideas@infragistics.com. Submitting your idea will send it directly to our product management team so that it can be imported into our new ideas community once live: http://ideas.infragistics.com.
Please let me know if any additional questions on this matter arise.
