Pls help me to remove dollar symbol from measure values.
Also give the idea to remove the (All columns - sub total) from displayed data.
Jims
thanks
Hello Jims,
Please clarify the DataSource that you are using for the PivotGrid. If you are using a FlatDataSource then there is a possibility to remove the dollar sign from measures by modifying the DisplayFormat property in the InitializeMeasureDescriptor event. You can refer to the attached sample on how to achieve this. For example, the DisplayFormat can be set to something like this:
void ds_InitializeMeasureDescriptor(object sender, InitializeMeasureDescriptorEventArgs e) { if (e.MeasureDescriptor.Name == "Budget") { e.MeasureDescriptor.DisplayFormat = "##.00"; e.MeasureDescriptor.Aggregation = MeasureAggregation.Average; } }
Also, AllMembers level can be removed only when it is a FlatDataSource and when FlatDataSource.GenerateCube method is used to create the cube. Once you clarify the DataSource I will further assist you with this issue.
Sincerely,Sahaja KokkalagaddaAssociate Software Developer
Why no replies to these clarifications
I mean remove 'All Items' when we expand the data.
