315
[Urgent] Adjust the control sizes as per the window
I have window which consists of Ultragrid and few of the other controls like dropdown, textbox etc.
My Requirement is:
Adjust the Grid & other controls size as per the Dialog resize
1. Allow wrapping in the  grid in the so that multiple lines will show to allow warnings to appear.
2. When the user resizes the Dialog, the grid and the bottom part(Warning and message) should be adjusted equally and not just the grid should be re-sized.
Adjust the Task Summary
Max of 3 lines are displayed for Task summary.(Task Summary column also gets wider to accommodate maximum content)
i.e. If the Task summary column has more data then the column is adjusted automatically to accommodate the extra text,which means that Warning and Drug Scanned column needs to be adjusted to become narrow when the content is less.
