165
UltratooltipManger
I got this code looking over the web
Private Sub UltraGrid1_MouseEnterElement(ByVal sender As Object, ByVal e As Infragistics.Win.UIElementEventArgs) Handles ug1.MouseEnterElement
Dim aRow As UltraGridRow
aRow = e.Element.GetContext(GetType(UltraGridRow))
If aRow Is Nothing Then Exit Sub
Dim tti As New Infragistics.Win.UltraWinToolTip.UltraToolTipInfo(aRow.Cells(1).Text, Infragistics.Win.ToolTipImage.None, "", Infragistics.Win.DefaultableBoolean.True)
UltraToolTipManager1.SetUltraToolTip(ug1, tti)
UltraToolTipManager1.ShowToolTip(ug1)
End Sub
But when hover over rows that does not have info it shows a blank tooltip, How to avoid this?
ariel
  • 7555
    Hello Ariel ,
    Thank you for posting to our forum.
    In order to avoid showing tooltip for the blank row you should have a conditional string check for that.
    Make a for loop to Check if your infor is not blank and then only in that loop call ‘ShowToolTip’ method.
    Please let me know if you need further assistance on this matter.
